the airfilter is located in the engine cover itself to remove cover grab it at the front and pull up but becarful you will break it if you pull to hard after you pull up the front just work your way around to release it on the backside of the motor after you remove the cover turn ti over remove the hose on the end with clap and then remove the scerws and replace filter when reinstallig put some lube on rubber groumets there should be 4 of them and set cover on engine center it and puch down lightly
Aug 21, 2009 at 1:44 PM
