HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volkswagen
Passat
Warning Lights
Check Engine Light
2005 Volkswagen Passat check engine light
CHEROKEE8381
MEMBER
2005 VOLKSWAGEN PASSAT
4 CYL
2WD
MANUAL
65,000 MILES
Check engine light is on but car runs smoothly
Monday, February 1st, 2010 AT 11:34 AM
MECHANIC
Have the computer scanned for code/s-you have a problem within the engine manangement system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
SPONSORED LINKS
Monday, February 1st, 2010 AT 3:41 PM
Please
login
or
register
to post a reply.
Related Check Engine Light Content
Check Engine Light On
Check Engine Light Came On And Car Was Idling Rough. Didn't Drive It And Tried Starting The Following Day. White Smoke Came From The...
Asked by
lmbus
2005
VOLKSWAGEN PASSAT
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
I Have Engine Light P0243 Coming Up. Some Times I Get...
I Have Engine Light P0243 Coming Up. Some Times I Get Full Psi Boost Sometimes I Get Nothing. What Is The First Thing I Should Do. I...
Asked by
Anonymous
2005
VOLKSWAGEN PASSAT
1998 Volkswagen Passat Check Engine Light
2.8 Litre , Check Engine Light Is On. Codes P0133, P1519. Im Pretty Sure That P0133 Is A Bad Oxygen Sensor But I Have No Idea About The...
Asked by
daleh5
1998
VOLKSWAGEN PASSAT
Check Engine Light
2006 Vs Passat 2.0t. Jerking Up Hills, Starting Off And When Idling. Check Engine Light Flashes And Stays Illuminated. Codes Are P000a And...
Asked by
will82ford
2006
VOLKSWAGEN PASSAT
P2181 Code, Recurring Cooling System Problem With...
Vehicle Is 2008 Passat Komfort With A 2.0tsi Engine. Problem Started With Unidentifiable Coolant Leaks, Stuttering Engine After About 3...
Asked by
WilfredOkany
2008
VOLKSWAGEN PASSAT
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Chevrolet
How to Read Codes
Code Read Retrieval/Clear Mercedes Benz
Online car repair manuals
