2004 Volkswagen Passat keeps over heating
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
INNERCITYDRE
hello, i wanted to know what could be the reason my passat keeps over heating. temp sensor has been changed along with some other parts that were worn out. thought the problem was fixed but after driving about 4 miles it started to overheat again. could it be the head gasket? do i need to just replace that or go for the engine swap? which reemdy is the cheapest?
Aug 18, 2010 at 12:00 PM
  • 31,937 POSTS
Hi there,
Before spending a fortune on an engine, replace the thermostat, have the radiator cleaned & checked fore partial blockages, replace pressure cap and check fore any external coolant leaks, start here.
mark (mhpautos)
Aug 18, 2010 at 9:39 PM
