2004 Volkswagen Passat
TLACINA
  • 2004 VOLKSWAGEN PASSAT
Engine Mechanical problem
2004 Volkswagen Passat 4 cyl Front Wheel Drive Automatic
Am getting an MIL light. Obd scann gives a code of PO411, Secondary air injection incorrect, upstream flow detected.
What does this mean and how can it be corrected?
Monday, February 8th, 2010 AT 3:03 PM
RACEFAN966
  • 5,029 POSTS
This means that either the secondary smog pump or the secondary air injection valve is bad. What I would check first is the fuse holder on far left side of dash behind an access panel this is the smog pump fuse it might be blown.
Monday, February 8th, 2010 AT 7:45 PM
