2004 Volkswagen Passat
2004 VOLKSWAGEN PASSAT
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIKECLARY
My passat shakes real bad and doesn't have any power, there is a light on that says it is the catalytic converter but we had that checked and it was fine. It was hooked up to a machine and it said that it was the spark plug coil but we replaced that 2 times. Can it be the injector and how do I replace it?
Aug 18, 2009 at 9:49 AM
STEVEW84
  • 673 POSTS
Need to know the code first. How did you check the cat. converter?
Aug 18, 2009 at 1:37 PM
