2003 Volkswagen Passat When I turn I hear noises, sounds li
2003 VOLKSWAGEN PASSAT
164,000 MILES • 4 CYL • FWD • MANUAL
SPICIN
When I turn I hear noises, sounds like bearings. But when I went to pull on the tires back and forth I get no clunking noises. Is this a costly repair? Could it be CV Joints and boots and such?
Mar 27, 2009 at 4:29 PM
ZACKMAN
  • 4,202 POSTS
Raise the vehicle. From under the car, inspect the inner and the out boots on the axle shaft. If any of them is torn, replace the axle shaft.
Mar 28, 2009 at 8:56 PM
SPICIN
I will indeed do this and let you know what I find. Thank you....
Mar 29, 2009 at 3:40 AM
