2003 Volkswagen Passat TIMING CHAIN
GASMAN2020
  • 2003 VOLKSWAGEN PASSAT
Engine Mechanical problem
2003 Volkswagen Passat 4 cyl Front Wheel Drive Automatic
HOW MUCH SHOULD I EXPECT TO PAY, AND SHOULD I GO TO A DEALERSHIP?
Monday, May 11th, 2009 AT 9:57 AM
BSCHURR
  • 45 POSTS
With the 4 cyl ft wheel drive you can expect a dealership to charge you approximately 1200.00. THis is because the entire front of the car has to come off in order to get the belts off & on the crankshaft pulley.
Wednesday, June 17th, 2009 AT 4:39 AM
