2003 Volkswagen Passat rough idle and shaking while acclera
ERICALJOHNSTON
Other Category problem
2003 Volkswagen Passat 4 cyl Wheel Drive Type unknown Automatic 63000 miles
I have a 2003 VW Passat. I recently had the 2 axles replaced. Ever since I have driven my car, I have felt shaking while accelerating. A shaking from left to right. Also the idle is very rough. While I am stopped a stop light and in reverse the whole car shakes. I have never had this problem before with the old axles. Does this have anything to do with the recent work done on my car? Thanks so much for your time.
Erica
Feb 3, 2008 at 11:32 AM
DJODC75
I have the same issue. Were you ever able to get this resolved???
My problem started after the timing belt was replaced. The car rough idles and shakes while at a stop. help!
Sep 24, 2009 at 4:15 AM
DRAHZZEL
Changing the timing belt really won't have any effect on the rotating mass to cause violent vibration. It would have to be driveline related, possibly a balance issue within the motor or the driveshaft itself.
Oct 10, 2009 at 12:27 PM
