2003 Volkswagen Passat One window will not work.
DAISYMOONZ
2003 Volkswagen Passat Manual 76000 miles
My driver side rear window will not go up or down. I believe it is out of the track. I can hear the motor running and I can manually move the window, but I am scared it is going to get stuck down (so we don't move it). Is there some way I can repair this myself?
Feb 9, 2009 at 1:17 AM
FRANKWEST
  • 9 POSTS
if you hear the regulator running up and down then that means the the plastic roll pin that holds the window in the regulator has fallen out just replace the roll pin and it should work
Aug 21, 2009 at 1:25 PM
