2003 Volkswagen Passat Oil Sludge Affect Turbo??
97,000 MILES • 4 CYL • FWD • AUTOMATIC
RGEBBIA
I recently had to have my engine replaced on this car due to a known oil sludge problem. Thankfully, it was covered under a special extended warranty. When I drove out of the dealer's repair shop, the engine light came on. After a few days of diagnosis, I was told that the turbo had failed but it had nothing to do with the oil sludge problem in the engine. Everything I have read about turbos indicate that proper oil maintenance is required for proper function. I changed my oil religiously with synthetic oil. I am out $1500 for this turbo repair and would like to know if I have a case against VW or is it likely that the two problems are mutually exclusive??
Dec 26, 2007 at 7:33 AM
  • 31,937 POSTS
Hi there,
The the turbo is basically an air pump driven by the expanding exhaust gasses. The turbo runs at extremly high temperatures and relies a good oil flow for lubrication and cooling, the oil will dissipate a huge amount of heat. If the oil gallery was still partly blocked by any sludge that restricted the oil flow, this may have had a bearing on the turbo failing. Unfortuanately you may be at ends to prove anything, but see how you go with a bit of extra knowledge.
Mark (mhpautos)
Dec 26, 2007 at 7:45 AM
