2003 Volkswagen Passat no reverse lights
2003 VOLKSWAGEN PASSAT
78,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRISC497
I was looking for info about replacing reverse light switch.I was told by some people vw electrical can be kind of funky.Where on the car is the switch located? Thank you in advance
Nov 4, 2009 at 3:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the automatic equipped Passat uses the multifunction transmission range switch to control the reverse lamps. it is located on the left side of the transmission.
Nov 4, 2009 at 4:06 AM
