Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volkswagen
Passat
Exterior Light
Hazard Light
Not Working
2003 Volkswagen Passat Hazards and Blinkers
2003 VOLKSWAGEN PASSAT
70,000 MILES • 6 CYL • AWD • AUTOMATIC
SHADOW077
MEMBER
1 POST
The hazard and Blinkers don't work. The fuses are good. I suspect it's the relay, but can't locate it. Can you tell me where to find it?
Aug 23, 2009 at 9:31 AM
DUBTECH
Experienced Mechanic
The hazard switch has the relay built into it. Most likely that is your problem and should be in stock at your local dealer.
Aug 31, 2009 at 6:47 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
