2003 Volkswagen Passat Hazards and Blinkers
2003 VOLKSWAGEN PASSAT
70,000 MILES • 6 CYL • AWD • AUTOMATIC
SHADOW077
The hazard and Blinkers don't work. The fuses are good. I suspect it's the relay, but can't locate it. Can you tell me where to find it?
Aug 23, 2009 at 9:31 AM
DUBTECH
  • 159 POSTS
The hazard switch has the relay built into it. Most likely that is your problem and should be in stock at your local dealer.
Aug 31, 2009 at 6:47 AM
