2003 Volkswagen Passat
2003 VOLKSWAGEN PASSAT
TONE-LOC
Transmission problem
2003 Volkswagen Passat 6 cyl All Wheel Drive Automatic
how to change tranmission oil, and were's do you fill it or check, and how much oil does it take, and what kind of oil do i use
Nov 23, 2008 at 2:49 AM
JAMES W.
  • 2,394 POSTS
There is a drain plug in the transmission pan similar to the engine oil pan for draining. It should take approx. 3 qts to refill. Fluid level is checked with the dipstick mraked "TRANS" on the handle.
Nov 23, 2008 at 7:26 AM
