2003 Volkswagen Passat
89,000 MILES • 4 CYL • 2WD • MANUAL
DLTALBOT
I have had my alternator replaced 3 times since christmas as my alternator workshop and battery light came one each time. It is 6 weeks since the last replacement and the lights flashed on again (the mechanic put it down to a faulty batch of alternators the last time it was replaced). I wondered if it could be anything else other than my alternator causing problems. I also had my battery replaced at chirstmas when the 1st alternator was put in.
I am at the end of my tether with it and would appreciate any help
Sep 11, 2008 at 10:00 PM
  • 31,937 POSTS
HI there,
have you had the so called faulty alternator bench tested to locate the fault, this may give a clue as to what i causing your problem. I would ask the mechanic if this as done, or just a new alternator was installed with out any diagnostic evaluation taken place.
Mark (mhpautos)
Sep 11, 2008 at 10:14 PM
DLTALBOT
The car has been tested at an auto electrical site for faults
Sep 12, 2008 at 3:20 AM
