2002 Volkswagen Passat timing chain / cabin filter
DREWDOKKEN
  • 2002 VOLKSWAGEN PASSAT
  • 6 CYL
  • AWD
  • 74,000 MILES
Looking at the front of my motor I have a metal cover over my timing belt? But is it a belt or chain? If a its a belt when should it be changed?
Also does my vw have a cabin air filter that should be changed?
Monday, December 17th, 2007 AT 9:51 PM
HIGHLANDER1
  • 5 POSTS
Is your car petrol or diesel?
The 2.5 tdi unit has a timing belt and you need special tools to lock the engine when changing the belt
cabin filter is located under the panel where the wipers are you have to lift of the trim that covers the battery and the filter is there
normally replace them every 10,000 miles
Wednesday, February 6th, 2008 AT 4:56 PM
