Code reader says P1570 engine no start
96,000 MILES • 6 CYL • AWD • AUTOMATIC
RWHITES
code reader says P1570 engine no start(immobilizer block) How do you reset ECM to allow engine to start??
Dec 21, 2009 at 6:18 AM
SQM
  • 6,383 POSTS
That code typically gets triggered if a non-programmed key gets used to start the engine.
Try this method to reset:
Turn the key to on position and wait 10 minutes. After 10 minutes the immobilizer light should go off. Then turn off the ignition. This will reset the immobilizer.
Dec 7, 2021 at 2:53 PM
