Hi there, my problem is that my car vibrates during accelerating, mostly felt with 3rd gear between 2000-3000rpm.Shakes even with other gears but not that notable as the 3rd one.Shakes only when accelerate, when I take my foot off the accelerator, shaking stops immediately.I don't feel the vibrations through the steering wheel or the accelerator, only through the gearbox.The gear stick shakes quite a lot and whole car as well.I asked my mechanic to check it out and he diagnosed it as it's faulty left drive-shaft, that we got changed for the new one.This solved my problem from about 30% only, car still shakes.I would really appreciate any advise as I don't want to spend any money till I'm 99% shure what it is.I understand that diagnose car without seeing it is not quite possible, but I would appreciate any clue or some test I can do to find out what that fault can cause. Thank you very much in advance Vasek
Aug 1, 2008 at 4:05 PM
