2001 Volkswagen Passat oil pressure
TRATKN
Engine Mechanical problem
2001 Volkswagen Passat 4 cyl Two Wheel Drive Automatic 110.00 miles
after the engine gets warm the oil pressure light comes on... i have changed the sending unit already... no knocking noise from the engine at all... any idea of what to try next
Mar 4, 2010 at 10:25 AM
2CARPRO JACK
  • 11,533 POSTS
Install a manual pressure gauge to verify it has good pressure. Do you happen to know what weight oil was used at teh last oil change?
Mar 5, 2010 at 2:06 AM
TRATKN
5w30 is what i always run in it i changed it after the light first came on did not help
Mar 5, 2010 at 8:43 AM
2CARPRO JACK
  • 11,533 POSTS
Verify pressure with a manual gauge.May want to try using 10-30 instead, it will stasy al ittle thicker when hot
Mar 5, 2010 at 9:04 AM
