2000 Volkswagen Passat Timiing belt
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS767676
It is time to replace the timing belt. The repair shop recommends replacing the timing belt tensioners along with the water pump. I undersatnd the water pump, but do the tensioners normally also get replaced when you replace a timing belt?
Apr 9, 2009 at 12:16 AM
  • 75,988 POSTS
If it was me I'll get the tensioner replaced
Apr 9, 2009 at 12:26 AM
