2000 Volkswagen Passat TAPPING NOISE
105,000 MILES • 4 CYL • FWD • MANUAL
ANNEMO
I JUST NOTICED THAT MY ENGINE IS MAKING THIS TAPPING NOISE THAT INCREASES IN SPEED IF THE ENGINE IS GOING FASTER--I PUT THE CAR IN NEUTRAL AND LISTENED AT AN IDLE AND COULD HEAR THE NOISE, THEN I REVED THE ENGINE A LITTLE AND THE TAPPING WENT FASTER.
I FEAR THIS IS REALLY, REALLY BAD...I'VE ALWAYS TAKEN VERY GOOD CARE OF MY CAR.
Aug 28, 2009 at 1:43 PM
  • 31,937 POSTS
Hi there,
This may be a faulty hydraulic lifter, you may be able to fix this by giving the engine a oil change with a good quality flush, this may clear any carbon deposits that may be impeding the lifter valve, if this dose not work the lifters must be replaced as a set, and make sure that who ever dose this is aware of the precautions with replacing these as if not they can do serious engine damage.
mark (mhpautos)
Aug 28, 2009 at 4:12 PM
