2000 Volkswagen Passat rough idle/random misfire/DTC Po112
2000 VOLKSWAGEN PASSAT
105,000 MILES • 6 CYL • 2WD • MANUAL
TRINIBALDHEAD
changed the following
plugs
plug wires
coils
fuel injectors
intake gaskets
performed compression test
May 1, 2009 at 1:14 AM
LEGITIMATE007
  • 5,121 POSTS
P0112 Intake Air Temperature Circuit Low Input
check the intake air temp. sensor and the mass airflow sensor may just need to be cleaned or replaced
May 1, 2009 at 5:52 AM
LEGITIMATE007
  • 5,121 POSTS
make sure the harnasses/connectors are clean and getting power, let me know how you make out
May 1, 2009 at 5:53 AM
