2000 Volkswagen Passat god damn door
16,000 MILES • 4 CYL • FWD • MANUAL
DRAGOVINGIAN
just trying to take the door panel off and there are only tow visible screws. Dont want to just force it off. I don't have the owners manual. how does one remove the door panel?
Jul 27, 2008 at 2:28 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2bdf824702="dragovingian"]Interior problem
2000 Volkswagen Passat 4 cyl Front Wheel Drive Manual 160,00 miles
just trying to take the door panel off and there are only tow visible screws. Dont want to just force it off. I don't have the owners manual. how does one remove the door panel?[/quote:2bdf824702]
You can get an answer with out the LANGAUGE!!!
There are Plastic door panel clips that are ribbed and you can slide a flat scew driver behind the door panel and carefully pry out and look behind to locate the plastic clips. then slide the screw driver up next to the clip and carefully pry out.
Jul 27, 2008 at 2:42 PM
DRAGOVINGIAN
What do you mean by LANGUAGE exactly.
Jul 27, 2008 at 2:50 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5435031541="dragovingian"]What do you mean by LANGUAGE exactly.[/quote:5435031541]
The subject you wrote......
2000 Volkswagen Passat[color=red:5435031541] god damn door[/color:5435031541]
Jul 27, 2008 at 3:04 PM
