I have a 2000 VW Passat that has a coolant leak. I purchased Prestone Super Sealer to fix the leak until I can get it fixed properly.
The instructions say to add water but I've read that adding water to a VW radiator can introduce rust and corrosion. Is this correct?
Should I go be what Prestone says to do?
Any help is appreciated.
Thanks.
Thanks.
Nov 9, 2008 at 2:42 AM
