2000 Volkswagen Passat Antenna Mast
2000 VOLKSWAGEN PASSAT
160,000 MILES • 6 CYL • FWD • MANUAL
MARK FLEISHER
how do I replace a broken antenna mast with a new one? thanks,
Nov 14, 2008 at 3:08 PM
IMPALASS
  • 3,112 POSTS
Hello - Since you didn't the specific type of Passat, this is for a Passat Sedan, 2.8L.
https://images.2carpros.com/forum/automotive_pictures/248015_1_65.jpg
Antenna mast 2 - Antenna base Amplifier is integrated into antenna base Removing and installing: Pull down headliner at rear Disconnect antenna cable -3- and remove nut -5-. 3 - Antenna cable Routed from antenna base to center console. 4 - Antenna cable Routed from center console to radio. 5 - Hex nut M14 With integrated serrated washer. Apply contact grease to roof panel when replacing . 6 *) Not for telephone system - Gasket
Nov 14, 2008 at 3:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The Passat models use a roof-mounted antenna, which is threaded into an antenna base. To remove the antenna, rotate the antenna mast counterclockwise to remove.
To remove the antenna base;
Remove the rear trim as necessary to allow access via the rear portion of the headliner.
Disconnect the antenna lead and if amplified, the wiring.
Using a 22mm (7/8 inch) short open-end wrench, loosen and remove the base mounting nut, then remove the base and if installed, the seal.
Installation is in reverse order of removal.
Hope this helped. Thanks for using 2carpros.com and thanks for the donation! It helps us help others!
Nov 14, 2008 at 3:33 PM
