2000 Volkswagen Passat ac belt
WILLIAMTURKOVICH
Air Conditioning problem
2000 Volkswagen Passat 4 cyl Front Wheel Drive 110000 miles
how do u change an ac belt
Sep 7, 2009 at 1:44 PM
DUBTECH
  • 159 POSTS
There is a tensioner/roller that is accessible from under the vehicle. Loosen both 6mm allen bolts and push the roller upwards. This will allow enough slack in the belt to slip it off the pulley.
You'll need to put a 17mm wrench on the bracket to tension the new belt while tightening the 6mm allens.
Sep 9, 2009 at 4:28 AM
