1999 Volkswagen Passat wont start
90,000 MILES • 6 CYL • FWD • AUTOMATIC
RDEHART2
I left an interior light on and ran the battery down. After recharging the battery, the engine turns over fine but the car will not start.
Nov 16, 2009 at 5:46 PM
  • 75,988 POSTS
Hi rdehart2 and TY for the donation
Lets do below to determine if its fuel or spark issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 16, 2009 at 5:53 PM
