1999 Volkswagen Passat Stalling; bad smell; ABS not functio
200 MILES • 6 CYL • 2WD • AUTOMATIC
SHERNAN1228
When I start my vw 199 passat, it stalls and there is a bad smell coming inside. Also, when driving it for more than 20 min. it the console displaying drive;park;reverse etc. goes black in the background and the car has no power;slows down. I have to pull over let it cool down and start it again. My ABS is not working properly, and when I stop makes a thumping noise.; while wobbling some.
Aug 19, 2009 at 6:32 AM
MERLIN2021
  • 17,250 POSTS
Probabaly two seperate problems, wobble with ABS light on could be a hub bearing up front, check both by jacking it up, shaking the wheels, if any play is noticed, replace all faulty parts. Other problem sounds like a clogged catalytic converter. Have the codes read, post all that are found.
Aug 21, 2009 at 9:15 PM
