1999 Volkswagen Passat Resetting The Check Engine Light
79,000 MILES • 6 CYL • FWD • AUTOMATIC
STYKEY
Is there any way of resetting the check engine light on a 1999 Volkswagen Passat? I tried disconnecting the battery, but that did not work. Is there a fuse that controls it that can be disconnected?
Aug 8, 2008 at 3:44 AM
KHLOW2008
  • 41,812 POSTS
Hi Stykey,
You need a Diagnostic Tester/Scan tool to reset. However if a fault is present, it will not reset until the fault has been repaired.
Aug 23, 2008 at 1:59 AM
