1999 Volkswagen Passat oil light staying on ,wont idle
1999 VOLKSWAGEN PASSAT
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
VANESSA CARR
just purchased 1999 passat oil light is staying on ,engine won`t idle starts without problem
May 28, 2008 at 1:18 PM
  • 31,937 POSTS
Hi there,
I would be getting the oil pressure tested with a master gauge, this will give you a true indication as to the engine oil pressure, if it is low you will have to get his investigated first. If the pressure is OK you may just have a faulty sender unit. Do this first and if OK, do a full tune and have the idle speed checked for the stall issue.
mark(mhpautos)
May 28, 2008 at 2:21 PM
