1998 Volkswagen Passat idle problem
JOSE ESTRADA
Engine Performance problem
1998 Volkswagen Passat 4 cyl Two Wheel Drive Manual
i got p1559 code engine said the throle body module is the problem i got the scaner but i dont have the right tool for check t.p.s sistem i like to knw if there is another way to check that
Jul 31, 2010 at 3:18 AM
  • 75,988 POSTS
If you have a volt meter you can check the TPS idle and wide open throttle voltages.
Jul 31, 2010 at 3:32 AM
