1998 Volkswagen Passat Hi
120,000 MILES • V8 • 2WD • AUTOMATIC
SBANTU
My car starts but doesnt move more than 5 mph and even moving at that speed it jerks.....the rpm doent go up even when given full accelertor
Aug 31, 2009 at 4:06 AM
DUBTECH
  • 159 POSTS
Any issues that happened that led up to this problem?
Is the MIL (Malfunction Indicator Lamp) illuminated on the dash?
Aug 31, 2009 at 6:41 AM
SBANTU
No there were no issues but the car stopped inbetween while driving a few days back it was just 2 or 3 times that happened but it was running smoothly.........i am not sure of the MIL but there is a icon on the dash board just below the icon which highlites when the fuel is over that is always on
Aug 31, 2009 at 6:58 AM
DUBTECH
  • 159 POSTS
You could have a bad/weak fuel pump. A fuel pressure test would be able to verify.
The pump and fuel level sensor are mounted together, so it would be a good idea to also have that looked at or replaced if it needs a pump.
Aug 31, 2009 at 11:52 AM
