1998 Volkswagen Passat FUEL LEAK
JOHN JACKSON1
1998 Volkswagen Passat 178000 miles
MY CAR IS LEAKING FUEL BETWEEN REAR PASSEGER DOOR AND REAR TIRE(RIGHT),
IS THERE A FUEL PUMP THERE AND MAYBE GAS TANK CONNECTIONS THAT NEED REPLACING
Sep 10, 2009 at 10:36 AM
DUBTECH
  • 159 POSTS
I highly recommend that you do not drive the car if there is a fuel leak.
The fuel filter is located in that position and is probably one of the fuel feed or output hoses leaking. Inspect for any cracked/broken hoses and for proper fittings of the fuel lines to the filter.
Sep 14, 2009 at 6:19 AM
