1996 Volkswagen Passat Front wheel bearings
140,000 MILES • 6 CYL • FWD • MANUAL
PASSAT9609
How do I and is it worth my time to replace the front wheel bearings myself? I'm assuming that all i need is the correct socket to remove the nut holding the hub on and then some sort of puller to remove the hub? Not sure on how to remove the bearing? Would appreciate any info on how to properly replace the bearing?
Aug 17, 2009 at 2:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_839.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_217.jpg
Aug 17, 2009 at 4:23 PM
