1991 Volkswagen Passat SIGNAl
EDISONS88
my signal switch does not working at all and i want to fix it myself, how can i do? thankyou.
Jun 9, 2010 at 1:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
do the hazard lights work? if so then signal switch may need replaced. first check fuse and signal flasher relay
Jun 9, 2010 at 3:23 PM
EDISONS88
the hazard light is working just the signal light does not working.by the way where is the k fuse and signal flasher relay locate? thank you very much
Jun 13, 2010 at 11:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
flasher relay is in the fuse block that is under the left side of dash. check fuse # 17 (10 amp, red) in the same fuse panel.
Jun 15, 2010 at 5:22 AM
