VW engine coolant into the engine instead of oil
VOLKSWAGEN
JOHNADRIAN71
HELP!
I have poured about 2 glugs of coolant / antifreeze into the engine thinking that it was oil.
What do I need to do now to save my engine?
Mar 29, 2006 at 3:32 PM
BENNY HAHA
  • 6 POSTS
Have you run the engine yet...if so, probably bad news-tow, don't drive to a trained professional to check for damaged gaskets/seals, block cracks, etc. caused by this mixup, if not, may get by with a thourough draining, including oil pan removal, and using something like a shop vac with special attachment to get into every nook to suck out all the antifreeze, and talk to auto parts store, they may have a product that could help remove any leftover antifreeze you can't reach...it still may have damaged seals, etc.
Mar 29, 2006 at 7:59 PM
