VW 98 Passat Igntion Lock 4
1998 VOLKSWAGEN
RICHSAN51
The key won't return to the run position when starting. You can physicaly turn it to run. The spring internally has either disconnected or broken. This is the second time. The last time was a typical $400 dealer repair. Is the spring mechanism in the lock cylinder or the lock housing? Replacing the cylinder is a do it your self job requiring no tools except a screwdriver and paper clip. The lock housing requires removal of the steering wheel and dealing with the air bag and best left to the pros. If anyone knows which piece has the spring mechanism that woiuld be helpful
Aug 28, 2007 at 10:11 AM
MERLIN2021
  • 17,250 POSTS
The spring is in the plastic connector part, called the ignition switch!
Aug 28, 2007 at 11:03 AM
RICHSAN51
Hi Merlin, Just to be sure the switch you are referring to goes in the end of the lock housing (opposite end of the key cylinder) Here is a picture.
https://images.2carpros.com/forum/automotive_pictures/96033_vw_Ignition_1.jpg
Aug 29, 2007 at 12:24 AM
