vw
VOLKSWAGEN
DT09591
automatic wont shift without grinding on 1978 vw bug
Nov 21, 2007 at 12:42 PM
  • 31,937 POSTS
Hi there,
The first thing to do is to check the transmission oil level and top up if low. Is the grinding when you try and select Drive or Reverse. Or when the automatic transmission is changing up / down gears ?
Mark (mhpautos)
Nov 21, 2007 at 12:57 PM
DT09591
both, forward & reverse regardless of direction or gear
Nov 22, 2007 at 7:36 AM
  • 31,937 POSTS
Hi there,
This is sounding more like a failed differential. Jack the car up and place on stands. Turn wheel the rear wheel, dose it make a noise and dose the other wheel turn backward? (that's normal) Hold one wheel, and turn the other, is there any strange noise.
I feel it is terminal but you should remove the transmission to inspect further.
Mark (mhpautos)
Nov 22, 2007 at 11:06 AM
DT09591
after some research we found the shift lever controls the actuation of the contact points in the linkage of the shifter which is controlled by an electric switch. Which operates a vacuum clutch release lever. the electric wire to the switch was broken, caused by moving the shift lever back and forth while shifting.
Thank you for your help. maybe our experience can help someone else.
Nov 22, 2007 at 1:01 PM
