volkwagen 1968 bay
1968 VOLKSWAGEN
LORNA
I own a 1968 volkswagen bay camper and I am having trouble. how do I go about removing stripped drive shaft bolts? I need to change the bearings and cannot do so as I cannot remove the driveshaft.
Sep 16, 2007 at 4:32 AM
MIKEYDEP
  • 29 POSTS
a 68? bay window?
do you mean the bolts that hold the inner cv's?
like, in order to remove the axles?
the axles are your driveshaft(s).
if you've stripped them trying to use an allen wrench,
you'll probably have to go with vice grips, those bolts
are a torx type, like, 12 points i think.
soak them well with penetrating oil and let them sit
first....
Oct 11, 2007 at 2:10 AM
