Trouble starting 85 vanagon
1985 VOLKSWAGEN
85VAN
I have a 1985 VW vanagon with 250k miles.
It turns over a couple times before starting (battery sounds a little weak), and doesn't start at all when warm. It'll just turn over when I turn the key.
Then I have to wait about an hour for the engine to cool before I can start it again.
Does the battery need to be replaced or is it something else?
Thanks,
Dominick
defino4@juno.com
Dec 16, 2006 at 6:08 AM
LOSONE
  • 1,616 POSTS
Your engine is far beyond it's normal life which is about 150K. With older engines, you tend to loose compression when the engine is hot. You may have a leaking fuel problem which further washes the cylinders lowing the compression. It could be as simple as needing a new set of Bosch plugs.
When attempting do not give it any gas. Crank with your foot off the pedal. Let me know
losone
Dec 18, 2006 at 1:39 AM
