Temperature gauge
VOLKSWAGEN
FLORESTA
Hi mY name si claudio and i have a VW Jetta wagon 2002, it has 75000 and is a 2.0.
When i am driving the temp. gauge do not rise like it is supouse to.
Stays as the car is cold all the time. It goes up for two seconds to the middle and than goes back to the left.
It is this a radiator problem? or it is just a simple thing that can be fixed?
Can i keep driving the car until is fixed?
Jun 23, 2007 at 5:32 PM
MATTC01
  • 10 POSTS
hello i would advise you to check your coolant temp sender. it is located on the left side of the engine in the coolant flange under the intake pipe between the throttle body and air box. if it is black i would replace it. vw is having a bad problem with coolant temp senders and i work for them i see it almost 2 to 3 times a day they go bad
Jun 25, 2007 at 1:44 PM
