temperature and leaking antifreeze
VOLKSWAGEN
SEXYLEXY178
i have a volkswagon cabriolet 1990 with about 94,000 miles on it. when i drive it the temp needle moves up within 10 mins of driving. then temp gauge then tells me that the car is at 100 degrees and climbing but never reaching the red. the antifreeze leaks onto the engine parts that are hot causing the car to smoke. the fan doesn't seem to turn on regularly either. i have to drive with the hood popped a little bit. what should i do?
Nov 27, 2006 at 1:49 AM
CANVIS69
  • 131 POSTS
[color=red:974b4701ab]fix the leak[/color:974b4701ab] first. second check the block for damage and if your gauge still freezescheack the engine coolant temp sensor and the thermostat
Dec 6, 2006 at 5:40 PM
FRIEDEMANN
  • 47 POSTS
Fix the antifreeze leak first. Being that it is a 90 car, the hose parts are all probably original (15 year old rubber) Thats a long time. They would be getting soft as they break down. Change them and change the thermostat(180F).
Get someone who knows what they are doing when it comes to putting in antifreeze(if you do hose changes) for it is not simply pour down into the rad neck or overflow and all will be good. Antifreeze has to be poured down the top rad hose into the engine to get fluid behind the thermostat and push out the air pockets.
If not done that way, the thermostat will not open.
Having the hood open does nothing for cooling.
Make sure that all the hose clamps are on tight. Now see where the indicatior needle stops at. That is when the thermostat opens. It will be before the red maybe a 1/4" maybe 1/8.
The fan sensor may be faulty, but you say it does turn on and off. That tells me it is working. Normally they will stick permanently on or off. The sensor is located on the driver's side of the rad with 2 wires. It is normal for it to be irratic. Comes on more often in slow moving city traffic and hot summer days.
The smoke or steam you see coming from under the hood is the coolant fluid steaming off. Fix it. Tighten the hose clamps if nothing else. So long as the needle doesn't go into the red, you are fine.
Dec 11, 2006 at 8:23 AM
