Rubbing Sound from front Disk brakes VW Jetta
VOLKSWAGEN
FREDG
Hi:
I recently had new Brake Disks and Pads replaced on my 1998 VW Jetta. The brakes are working very well but from time to time I hear a rubbing sound as the car comes nearly to a stop.
While riding at speed, there is no sound. Only after fully applying the brakes and coming to a near stop can you hear a rubbing sound that seems to correspond to the wheel rotation.
Could there be something loose? something installed incorrectly that is rubbing?
Thanks,
Fred G.
Oct 20, 2007 at 10:28 PM
  • CAR REPAIR CONTRIBUTOR
If it continues everyday then there's a problem upfront-take it back.
Could be rotors that have been improperly finished or brake parts not installed properly.
Oct 20, 2007 at 11:32 PM
SERVICE WRITER
  • 9,123 POSTS
It wouldn't hurt to have them looked at where you had the work done. Every so often I get a set of pads that I think are on the aggressive side and sound a little coarser than you would expect.
Oct 21, 2007 at 6:43 AM
