2004 Volkswagen Jetta Vibration Noise
VOLKSWAGEN
DUTTONMN
I have a 2004 VW JETTA with 34,000 miles on it. I just bought new tires less than 1,000 miles ago, had them balanced, and the works done to them.
I brought it back to sears where i had the tires installed, and had them re-balance them. Because they have said that with VW Tires, they are unable to put the standard car weights on the tires because of the design.
However, i was told by a colleague that it may be my cv joints. Because when i go around corners, or am driving at a high speed i have vibrations, and almost rubbing noises. Should i take it to a mechanic to have them investigate, or should i just go ahead and replace the cv joints myself.
My fiance is a mechanic in the Coast Guard, so i'm thinking that he migh be capable of doing this task. Please tell me if i'm way over my head.
Oct 15, 2007 at 6:22 AM
SERVICE WRITER
  • 9,123 POSTS
Call the dealer and see if you are still under factory warranty for that.
May be a bearing problem.
Oct 15, 2007 at 6:35 AM
DUTTONMN
You were right...it was in fact a bearing problem!
Oct 16, 2007 at 4:42 AM
SERVICE WRITER
  • 9,123 POSTS
Almost like I know what I'm doing :wink:
Oct 16, 2007 at 9:55 AM
Suggested Repair
Have the wheel bearings inspected rather than replacing the CV joints first. The vibration and rubbing noise was confirmed to be a bearing problem; also check whether factory warranty still applies.
Conversation Summary
The owner of a 2004 Volkswagen Jetta with low mileage reported vibration and rubbing noises in corners and at higher speeds after new tires were balanced, and wondered whether the CV joints should be replaced. The expert suggested checking remaining factory warranty and said it might be a bearing problem. The owner later confirmed it was a bearing issue.
