Neutral Safety Switch - 99 VW Jetta (new body style)
1999 VOLKSWAGEN
KLADZINSKI
I have a 1999 2.0 VW Jetta with 85,500 miles on it.
The other night, I was looking through my trunk for some thing and noticed that the trunk light was hanging down. I pushed the trunk light back into position and it burnt out and/or broke. I then shut the trunk and realized that my interior lights were no longer lit. I tried to start up my car and that didn't work. My windows, locks, trunk and keyless remote will not work. My headlights do work though.
My brother-in-law changed the relay and detached then reattached the battery and unplugged the trunk light.
Nothing is working ....PLEASE HELP!!!
I found some questions that people asked about the neutral safety switch. Is the neutral safety switch what I need to look for and where is it located? :cry:
Jun 23, 2007 at 6:57 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you grounded out a system and probably blew a fuse if the entire interior is dead. Check every fuse in the car with a test light
Jun 24, 2007 at 2:11 AM
KLADZINSKI
Thank you for your reply!
The main fuse was changed and the fuse box that is located on the left side of the steering column was checked and all tested fine. We also tested the electrical flow to all areas that we could think of and reach.
Is there another fuse box that is located under the battery or somewhere that is hidden or hard to access??? :?
Jun 24, 2007 at 3:35 AM
MATTC01
  • 10 POSTS
i would check your comfort control module all those components are controlled by that module it is located under the left side of the dash to the left of the steering wheel black box i would start by getting one maybe from a bone yard but make sure the part number is the same if you can
Jun 25, 2007 at 1:41 PM
