1992 Volkswagen Passat Engine Surge
Try a few tanks of gas with fuel injector cleaner. I like chevron with techron.
How many miles? Might need to clean the throttle body, idle air control valve and the EGR valve. Alos checlk for vacuum leaks.
Good luck and let us know. :)
peppermrj
Why was it changed?
I had a customer that had a car that wouldn't start, so they went through a series of bizarre motions and it started when they did that, and assumed it had to do with what they were doing when it reality it had nothing to do with the trouble source.
Because you ran low on fuel may have nothing to do with the problem.
It has 130,000 miles on it.
Thanks Ill give it a shot and let you know what happens.
Hey Markie,
peppermrj
Suggested Repair
Run several tanks of fuel with injector cleaner such as Chevron Techron. At 130,000 miles, clean the throttle body, idle air control valve, and EGR valve, and check for vacuum leaks. The fuel-pump replacement may not have addressed the actual cause.
Conversation Summary
A 1992 Volkswagen Passat 2.0 surges at idle and during acceleration or deceleration but runs normally once underway. The owner replaced both fuel pumps and the fuel filter after running very low on gas, without improvement, and says it feels like it is not getting fuel when pulling away. Experts suggested injector cleaner, cleaning the throttle body, idle air control valve, and EGR valve, and checking for vacuum leaks, while noting that running low on fuel or replacing the pumps may be unrelated.
