1994 Volkswagen Jetta Turn Signal Cranks Starter Fix
VOLKSWAGEN
THUNDERBUT
I have a 1994 volkswagon jetta with 97,449 miles
the vechile was given to me and i have started to do some repairs to it but, when i turn the ignation on and trun the rh turn signal it turns the car over(starts it) but if i do not turn off the signal the starter starts to grind. I have only found one cut wire behind the fuse box that was jumped to a hot wire( thinking is hot) what do i do if any thing. also the radio was replace ( non-factory) if this helps any
Aug 13, 2007 at 2:27 PM
  • 75,988 POSTS
[quote:de67a1d67e="thunderbut"]I have a 1994 volkswagon jetta with 97,449 miles
the vechile was given to me and i have started to do some repairs to it but, when i turn the ignation on and trun the rh turn signal it turns the car over(starts it) but if i do not turn off the signal the starter starts to grind. I have only found one cut wire behind the fuse box that was jumped to a hot wire( thinking is hot) what do i do if any thing. also the radio was replace ( non-factory) if this helps any[/quote:de67a1d67e]
If it was me I'll find the starting circuit wire on the harness going to the ignition switch cut it off and tap in then take it straight to the starter or relay/solenoid.
Aug 13, 2007 at 8:26 PM
Suggested Repair
Locate the start-circuit wire in the harness to the ignition switch, cut and tap that circuit, and run it directly to the starter or the starter relay/solenoid.
Conversation Summary
The owner of a 1994 Volkswagen Jetta said turning the ignition on and using the right turn signal cranks and starts the engine, and leaving the signal on makes the starter grind. A cut wire behind the fuse box was jumped to a hot wire, and the radio is aftermarket. The expert advised isolating the start-circuit wire at the ignition-switch harness and routing it straight to the starter or relay/solenoid.
