Golf Gti 2.0 L 8valve 1995 stalling every now and then.
1995 VOLKSWAGEN
MISHANEMO
Hi there;
I have got a 1995 Golf Gti, 2.0L, 8 valve, ADY engine. 150000 miles .
I am having seriously annoying problems with the car just cutting out on me as I start braking. The car also seems to drive fine as long as I don't accellerate hard. The car seems to have no power, especially above 3000 RPM.
I have read most of the forums and these are the things that I have replaced so far.
I have replaced the ECU relay, FUEL PUMP relay, HT leads, spark plugs, fuel filter, lambda sensor. I have also done a compression test and all 4 cylinders were around 13 bar, which I am told is fairly good for an engine with such high milage.
Could this problem be caused by a faulty crank speed sensor, evaporative emission system purge valve, airflow meter or idle speed control valve?
Please can you help me as this is costing me a fortune replacing all these parts.
Many Thanks.
Daniel
Jun 17, 2007 at 8:45 AM
RABIHBOUTAYEH
dear Mr. Daniel I'm Rabih Boutayeh and I have a same car I think your problem is an electric problem and I think: you should change the ECS Ignition System Kit
https://images.2carpros.com/forum/automotive_pictures/82623_420_x150_2.jpg
Jun 29, 2007 at 4:58 AM
