1999 Volkswagen Jetta Fuel Leak
VOLKSWAGEN
JESSICABECERRA
i noticed my car smelled a lot like gas and that my tank would empty a whole lot faster. yesterday i noticed my car was literally pouring out gas from underneath. i had my friend check it out and he said that the top plastic piece of the fuel pump had a crack and was spilling all of my gas. is it possible to just replace the top of the pump (it looks like it's 2 seporate pieces), or would i have to replace the whole pump?
1999 jetta, volkswagen/ 80,000 miles/ engine-4 CYL, 2.0L
Sep 29, 2007 at 8:35 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0973c611a0="jessicabecerra"]i noticed my car smelled a lot like gas and that my tank would empty a whole lot faster. yesterday i noticed my car was literally pouring out gas from underneath. i had my friend check it out and he said that the top plastic piece of the fuel pump had a crack and was spilling all of my gas. is it possible to just replace the top of the pump (it looks like it's 2 seporate pieces), or would i have to replace the whole pump?
1999 jetta, volkswagen/ 80,000 miles/ engine-4 CYL, 2.0L[/quote:0973c611a0]
Extra caution must be taken when dealing with gas and fuel leak .
If its leaking from the fuel pump it self you have to replace it as a unit
But check to make sure its not a fuel line
Good luck
Let us know
Sep 29, 2007 at 10:41 PM
Suggested Repair
If the leak is from the fuel pump itself, replace the pump as a complete unit rather than only the cracked plastic top. Also inspect the fuel lines to confirm they are not the source, and use extra caution around gasoline leaks.
Conversation Summary
The owner of a 1999 Volkswagen Jetta reported a strong gasoline smell, rapid fuel loss, and gas pouring from underneath the car. A friend thought a crack in the plastic top of the fuel pump was the cause and asked whether only that piece could be replaced. The expert advised caution with fuel leaks, said a leaking fuel pump should be replaced as a unit, and recommended checking that a fuel line is not the actual leak.
