CODE P-3081
2012 VOLKSWAGEN
TERMINATORS
hi i have a volkswagen jetta 2002 1.8t 20 valve
it has 72.000km and i recently got this check engine light and the code reads p-3081 air metering auxiliary emissions controls what is the problem i should be looking
at but yet the car runs just fine
thank you
Nov 21, 2007 at 3:06 AM
P1S7OL
  • 45 POSTS
I would start with the secondary Air injection system. It could be a number of things there. Air pump, Vacuum Valve, Check Valve, Fuse, wires, Solenoid, You would just have to go through and check it. Hope this helps!
https://images.2carpros.com/forum/automotive_pictures/119074_Jettainhouston_1.jpg
Nov 21, 2007 at 4:19 AM
